Old 04-15-2015, 07:23 AM   #2
CharlieChalk
Originally Posted by antny View Post
If you take the headlight out and look inside. On the left side you will see a screw attached to a black plastic piece. That black piece is what broke off the arm that moves the headlight up and down when you turn it.
Right OK, so best way to find out is to take the headlight out and have a look?
Is there really no replacement part? Do you have to get an entire new headlight, what's the rough cost? Mine are the xenon/blue-ish ones with washer jets...
What are the chances that this could happen to both left and right lights simultaneously? The lights were fine, but since i had the car back from the garage (rusted bolt on a wishbone affecting the tracking alignment) the headlights are now too high.
Thanks for the help
CharlieChalk is offline   Reply With Quote
