I have a 99 base. There is an "overfill" discharge hose for where the coolant reservoir/oil filler is located that drains by the right rear wheel. Take off both fill caps and remove the flat plastic horizontal plate under them. You will have to pull off the rubber gasket/ring above it. Almost center in the bottom there is the overflow tube. Pour some water in it to see if it is coming out where your leak is. If so you might just need just need a new coolant cap
