Old 03-26-2015, 09:12 AM   #4
ganseg
ganseg's Avatar
Hi,
take a look at the sheet i've attached. There you'll see the wheel align values. As you are livning in the UK, please use the clumn RoW Series for orientation.
It seems that they didn't adjust the camber on the left side. Maybe because you can't adjust camber on most older MB cars. Also it takes a lot longer to adjust everything to specs.
Over here in germany it is very important to adjust wheel alignment very correct, because the car is sensible at high speeds.
Regards Markus
Markus or others, what column would I look at on your chart? I have a US car with 030 on the options list stuck inside the front hood. And in the camber column, how do I translate that to degress of camber? Thanks.
ganseg is offline   Reply With Quote
