Originally Posted by Topless
Maybe have a shop scope the offending cylinder and see what's up. If it's just a valve spring it's a pretty easy fix. If a grenade went off in there then swap the motor and keep on driving. Lots of decent motors sitting at dismantlers still for not to much money. I'm not ready to dump the car yet.
Find a local indy shop with lots of 986 experience through your local PCA.
+1 or buy an inexpensive scope and do it yourself. If the piston is damaged or there is anything in the cylinder that should not be, the cost for repair is very likely more than the car is worth. something beat up that spark plug and it wasn't a non functional valve. Pulling the valve cover off is more work than just scoping the cylinder.
