Old 03-23-2015, 04:30 AM   #1
particlewave
Originally Posted by oc-boxster View Post
My battery is about 2 years old But the car sat without running for 2 weeks. Normally I use a battery maintainer, but without being able to open the lid I couldn't this time. The battery drained down once before while my mechanic had it for a couple weeks, so I'm going to replace the battery along with the latch. Makes me wonder how long you can let a boxster sit without starting without the battery draining all the way down, assuming the battery is fully charged and good.
My battery is now almost 4 years old and I regularly go for 2 to 3 weeks without starting it, all the while using the car to test and align customers headlights.
Even after that, the battery cranks fast and hard as if it was not affected at all.
You either have a bad battery or a slight parasitic drain. When your mechanic drained the battery, he really should've replaced it because they are never the same after that.
