Thread: INTRO to group
Old 03-21-2015, 03:23 PM   #1
Desert Bill
Desert Bill
INTRO to group
I would like to thank all the posters to the group. Your knowledge has helped me in my quest.
I purchased a " dead" 2000 Boxster S from a dismantler before it was completely gone.
Previous owner had purchased in August and sold in January-Oil in coolant. It did have new coolant tank and evidence of previous leak in rear trunk. It was missing front trunk lid ( 2 ft. of water in front trunk!),battery missing,along with Steering Wheel and air bag. The driver's window down, immobilizer soaked,mildew on driver's seat, door panel, and dash side. pollen filter dirty,rear bumper missing, spoiler (early type) off in trunk, ashtray and cover missing. No oil on dipstick or coolant in tank. No attempt to crank made. Car was rolling on 2 spares and 2 aftermarket "CUP" wheels which had seen better days-4 spoke steering wheel w/o air bag installed. Evidence that back console and speakers removed from indentations in rear rug.
STRONG HINT: BUY A COMPLETE CAR!
So to restore car to completeness the following were obtained: ( This can be expensive!)
3 Spoke Steering Wheel and Air Bag
Front Hood and Crest
Battery-Bosch
later 2003-2004 rear bumper with parking assist holes was installed-need plugs
spoiler pieces for later bumper (Supposedly more aero than early)
non smoker option for ashtray and cover
19" 2006 Carrera Sport wheels with Michelin Sport tires (rears are worn and need replaced)These allow locks and standard bolts for mounting.
pollen filter ( I don't think it had ever been changed1)
distilled white vinegar to work on mildew on leather, but if that doesn't work in long term, bought vinyl door panels from 2003-4 with Bose speaker covers, actually later panels look better to me than early.
Rear console from E-bay, speaker kit from Sunset.
Bentley Boxster Manual and Wayne Dempsey's 101 Projets for Porsche Boxster.(Both MUST have!)
Pelican Parts Website forum and update to projects for more info. LS376 Video's have helped me a lot!
So that leaves the engine problem. 75009 miles on odometer, M96.20 engine with oil in coolant, sold to dismantler at give away price. Porsche wants $1000 more for core than replacement remanufactured engine cost. Let's just say 43K(with sales tax) plus you pull and replace, with 15 year old ancillaries. Do it yourself -unknown cost and problems-plus learning curve and tool's.cost. Or have independent shop, one quote, minimum cost" could be around 8K to ?" Current market price for Boxster S? Will rebuilt engine be reliable?
I have offer for $1500 for long block w/o ancillaries. I needed
alternator, A/C Compressor, engine harness, oil pressure switch,engine compartment temp switch and will try to use oil level sensor along with new dipstick.
I was impressed by the Renegade Hybrids conversions of the 928,996 986 and 987C.
Making a pest of myself, I visited the shop when I could, asked questions and tried to take pictures ( I am lousy photo taker!) and finally pulled the trigger.
Last week I took delivery of LS-3-480 hp with ECU ,Corvette oil pan,oil pickup, windage tray and Corvette engine mounts. I previously had picked up the kit from RH and exhaust components. Also picked up factory hard top. Next, to get 2 post lift installed, when I get home from current trip.
I purchased female sockets(from Pelican) to get seats out, so can strip interior for conversion. I stripped the front and rear trunks of carpet already. Once top disconnected and removed, will pull electrical brains - before welding. I have checked current instrumentation and controls-Oil level,Oil Temp,Airbags- read bad. Even radio works with code, climate control,wipers, lights and mirrors.
Everything is still connected, so will try to move convertible top to maintenance position, after check relays and micro switches (first attempt failed). Any other hints, gratefully accepted!
For those doing the conversion using the RH kit, each builder will differ in the build of their project. You have different years, engines, design intent and skill level. Everyone will do things "their" way. Your budget will determine a lot of of your time required. If you are modifying a junk yard engine and spending your time looking for parts to use and comparing prices, I think you will be surprised as to how much time you use. I was surprised how long it took, just for finding hardware for mounting components and hoses That's why I went with crate engine, but if you can find 2008 Corvette for good price, in good shape with manual ECU, you could change cam later.
Suggestion for those converting a 986 to LS-3, get 987 top engine cover - it's aluminum and will
cover opening behind seats after LS-3 installed easier than anything else you can find.
Sorry so long, but it's an intro. Here's a picture:
Desert Bill is offline   Reply With Quote
