Old 03-13-2015, 05:17 PM   #1
patssle
Some vacuum is normal on the oil fill cap. If you can test the pressure - normal is 5 inches. They say if AOS is bad then there is a ton of vacuum.
Also don't run the engine much if you can - they say too much oil coming from a failed AOS can ruin it.
