Old 03-11-2015, 03:03 PM   #14
The Radium King
The Radium King's Avatar
Originally Posted by JAAY View Post
Radium<<<<<<<<<<< Thank you for the better explanation.
actually - you are the man here, as you've actually gone in with a piggy back and modified your fueling. perhaps you could help me - does the ecu use the trims established in closed loop operation to modify fueling when running open loop? you could probably determine that by resetting your ecu - as it re-adapts and resets trims, do you see open-loop fueling changing?
