Old 04-20-2006, 09:54 PM   #7
MNBoxster
Originally Posted by red_wagen
Point taken. But lest you be mistaken that I'm cheaping out on the car, I'm not. But I'm not Mr. Moneybags either so hence the question. How much mileage can one expect from a set? 10k? I know actual mileage may vary...
I should point out again that I'm not running away from this car simply because I might "only get 10K miles out of a set of tires". I was just curious...
Hi,
Driven normally (which is of course a relative term), you should expect to get say 20k mi. from the Fronts and perhaps 15k mi. from the rears.
Your driving style, the area of the Country you reside in and how careful you are at maintaining proper Tire pressures will affect the actual lifespan of the Tires. Hope this helps...
Happy Motoring!... Jim'99
