Old 03-04-2015, 03:52 PM   #10
flaps10
flaps10's Avatar
"Unfiltered" is slightly misleading. We're not talking about "never been filtered nasty, metal filled oil", it's oil fresh off the oil pump, immediately before the oil would have been rammed through the filter.
That would make it the same as the splash oil supply used on any other option but the Solution which isn't available to all of us.
One could argue that the LN Solution uses "uncooled" oil since it takes the oil from the filter base but prior to going through the cooler (the next step in the oil path). That would be an unfair claim.
I'd say in both cases the oil is being filtered and cooled several times per minute.
And yes, I have the LN filter and magnetic drain plug ready to install.
flaps10 is offline   Reply With Quote
