Sounds like the chain adjuster is failing. Get some diagnostics on it before you go mechanically inside. If the timing is 25* out, the adjuster has failed. The other possibility is severely worn chain wear pads on the chain adjuster.
This is if its a 5 chain engine.
US Patent 8,992,089 &
US Patent 9,416,697
