Old 02-28-2015, 03:37 PM   #11
juncojones
I'm at the exact same spot, but with a newer generation cluster. It looks GREAT!
Im using the original board form the boxster and the 996 gauges. I've already Transplanted the two flat cable connectors for the new gauges, but no activity at all in that front. I assume they need to be powered on form the cluster itself.
Does anyone knows the two bytes I need to change to enable the Volt and oil pressure gauges? From what I've read, the bytes are different between the 2 type of clusters, but can't find any data for the new generation ones.
Thanks!
juncojones is offline   Reply With Quote
