Old 02-25-2015, 04:36 PM   #11
Reebuck1
Reebuck1
996 Gauges
Looks like I made another mistake....received this great suggestion
Hi ,
One thing that jumps out is that due to the read being byte swapped by the programmer the wrong byte has been changed for the voltmeter. This is why the unit is now in KPH, you accidentally changed the byte that controls that function. (BB changed to 01 at x00005006)
I have put it back as it should be, changed the correct byte for the voltmeter and written it to a new file. Try uploading this and see how it functions.
The pressure gauge should be working with this program though, so I do not know why it isn't. Have you checked your wiring and have a known good 996 sender unit installed?
Cheers
I'm on it THANKS !!!
Reebuck1 is offline   Reply With Quote
