Old 02-25-2015, 09:08 AM   #13
drumboxer
Ok, you guys are awesome. Please take a look at my notes/questions below:
so, just to get my terminology straight, and working from out to in, you have:
Thanks for clarifying, I want to be sure I am on the right page: Here is what I was planning to use:
snorkel - part of the airbox? If so, 987
air box - 987
maf and holder - 987
intake pipe - Sounds like I need to fabricate one? (I have a manual trans btw)
throttle body - 996
plenum - 996
intake manifold - 996
from what I gather (haven't done this, but some have) the 996 intake manifold will fit on the 986 motor, however it (a) is taller and requires the 987 engine cover, and (b) only has two of the six fastening points match on each side. as a result, you have to (a) tap two holes on each side, and (b) fabricate two brackets on each side. Thank you, this is helpful. I am planning to use the 996 manifold, so I guess tapping new holes will be necessary.
re the tune, it is required only if you change the diameter of maf holder (different diameter means different air readings to the computer). ie, if you use a 987 maf holder to match your new air box then you need to retune you engine as it is a larger diameter than what the computer expects. you can reuse the maf holder currently in your car by sawing it off your old air box, or find a bmw unit (or any car that runs a bosch system) of the same inside diameter; this way don't have to do anything with the computer. If I have to send the ECU away to retune anyway, would I be better off with a custom tune that accounts for my motor and each modification made?
the design of the intake pipe from the maf holder to the throttle body will depend on your decision on what you are doing with the maf holder. I reused by original maf holder and was able to get away with reusing the old intake tube and getting a 90 degree reducing elbow to mount on the throttle body (the inside diameter of the new throttle body is 3" but the outside is 3.25" due to the thickness of the lip - you want an elbow that reduces from 3.25" to 3"). probably the best approach is to get the manifold/plenum/throttle body on, and the air box and maf holder in, then figure out what you need to get the two to join. if you want a super duper oem look, then IPD make a pipe for the cayman that should do the job (the IPD plenum is about the same dimensions as the 997 plenum, so should fit right up provided you take the 987 maf holder route). - And if I intend to use the 987 MAF holder? My understanding is that this is optimal so as to not create a bottleneck with the smaller diameter 986 housing.
2003 Boxster S - Street/Track
1976 Carrera 3.0 - Project
2008 Cayenne GTS - Grocery Getter
drumboxer is offline   Reply With Quote
