Old 02-25-2015, 07:33 AM   #12
The Radium King
The Radium King's Avatar
so, just to get my terminology straight, and working from out to in, you have:
snorkel
air box
maf and holder
intake pipe
throttle body
plenum
intake manifold
from what I gather (haven't done this, but some have) the 996 intake manifold will fit on the 986 motor, however it (a) is taller and requires the 987 engine cover, and (b) only has two of the six fastening points match on each side. as a result, you have to (a) tap two holes on each side, and (b) fabricate two brackets on each side.
re the tune, it is required only if you change the diameter of maf holder (different diameter means different air readings to the computer). ie, if you use a 987 maf holder to match your new air box then you need to retune you engine as it is a larger diameter than what the computer expects. you can reuse the maf holder currently in your car by sawing it off your old air box, or find a bmw unit (or any car that runs a bosch system) of the same inside diameter; this way don't have to do anything with the computer.
the design of the intake pipe from the maf holder to the throttle body will depend on your decision on what you are doing with the maf holder. I reused by original maf holder and was able to get away with reusing the old intake tube and getting a 90 degree reducing elbow to mount on the throttle body (the inside diameter of the new throttle body is 3" but the outside is 3.25" due to the thickness of the lip - you want an elbow that reduces from 3.25" to 3"). probably the best approach is to get the manifold/plenum/throttle body on, and the air box and maf holder in, then figure out what you need to get the two to join. if you want a super duper oem look, then IPD make a pipe for the cayman that should do the job (the IPD plenum is about the same dimensions as the 997 plenum, so should fit right up provided you take the 987 maf holder route).
