Old 02-21-2015, 04:25 PM   #1
papasmurf
If the top has the cable's falling outside of the trim piece
like in the photo posted, there is a chance that the tension springs at the base of the top above the door are flipped especially if the top has been replaced and someone put them on backwards. I put a new top on my car a few years ago and could not figure why the straps kept falling outside the window frame when I was raising the top. I tried everything possible with the straps before someone told me that the (leaf) springs could be backwards. They took about 5 minutes to turn around and low and behold it worked like a champ from there on out. If the top has been raised with the cable's outside the frame there is certainly the chance that the cables could be stretched.
papasmurf is offline   Reply With Quote
