Old 02-21-2015, 09:30 AM   #11
Slate 01
Originally Posted by rfuerst911sc View Post
Guys I'm dusting off this thread to ask a question about these sure seal clamps. Can they be used in place of the other factory clamps ? I have a slight leak on both sides and regardless of how I position the OEM clamps and how tight I can get them they still leak. Will the 2 " sure seal clamps work ? I want to use them on both sides of the U pipes.
Yes. Go take a look at them and you will totally understand the function and how they properly seal a pipe. You can get just about any size you need at Napa. If you don't see the size, you can order it and it typically is there the next morning.
