Old 04-19-2006, 08:26 AM   #12
EPIQTodd
Originally Posted by Biz-z Z
I recommend you get a 4 wheel alignment immediately, watch your tire wear like a hawk and sing out loud and soon if they seem to wear unusually quickly. Rear tires alone will cost in the neighborhood of $650-700 to replace. From what I understand they are ultra performance tires with soft sticky rubber and typically last 10,000 miles or so with some going further depending on your driving habits.
I drove my Box 3 months last season and 3 weeks this season for a total of 3900 miles. The fronts are like new but the rear tires only have 3/32's left. They seem to be worn pretty evenly and no I don't drive crazy, I drive like an old lady. I hate to admit it but it's been all highway(back and forth to work) and a few weekend tours (with my wife) so no spirited driving. Have kept the air at 32F, 36R religiously and I've been extremely careful to the point of obsession about avoiding potholes, bump, curb etc. It's hard to believe the tires could wear like this. I will be going to the dealership(Boston), Friday to see what they will do. I don't hold out much hope. The dealer has probably heard a hundred stories like mine.
So, an immediate 4 wheel alignment (documented) and continued vigil is what I would recommend. It may save you headaches later. Sheesh! I wish I were this smart last year.
Great advice - get an alignment. The factory alignment is almost always unequal. I had mine done when I had my camber adjusted and even the camber was uneven - the fronts were negative .1 degrees on one side and .3 degrees positive on the other - POSITIVE!
Todd
2005 Boxster S - Atlas Grey/Black, PASM, Sport Chrono, Bose
2006 Infiniti M35 Sport
2007 Cadillac Escalade (tow vehicle with bling)
'00 Boxster - 2.7l w/FVD ECU tuning, Moton double adjustable suspension, custom stainless headers, lightweight flywheel, dual Magnaflow mufflers, 18" CCR wheels, 911 front brakes in front, Boxster front brakes in rear, full welded cage.
http://www.epiqautosport.com/images/epiqtoddavatar2.jpg
EPIQTodd is offline   Reply With Quote
