Old 02-19-2015, 02:52 PM   #26
luci5r
luci5r's Avatar
Originally Posted by tommy583 View Post
There are most likely two clips that hold the battery in the car. They will be on either side of the battery near the bottom. You will have to loosen the bolts that hold them down. Then just unhook the positive and negative terminals and take the battery out.
On a side note you should invest in a battery maintainer of some sort. I use a battery tender jr. When batteries are allowed to discharge completely a few times, they don't last as long. As you can tell by your newish battery not taking a charge. Hope this helps
Right, I did see those; those shouldn't be a problem.
I'm seriously considering picking up the Interstate MTP-48/H6. Unless anyone has suggestions otherwise.
I honestly don't know how long the MTP-91 has been installed; if it has been since the beginning, it's obviously over 10 years old. If it was replaced down the line, then anywhere between 3 to 5 years I would say. I'm not sure if that's normal or not.
luci5r is offline   Reply With Quote
