Old 02-19-2015, 04:48 AM   #2
Pominoz
Pominoz's Avatar
You can buy the pieces from a stealership and drill holes in your rollbar and use a rivet to secure the pieces and voila! you have a factory looking center windscreen.
Call Sunset Imports in Oregon. Their prices are good for out of state purchasers.
I'd buy the actual windscreen and rollbar inserts used off fleaBay if I were you. They're awfully expensive from the stealership's parts counter.
I bought a used wind deflector from a Porsche scrap yard. The frame needed the fastening levers replaced, and the perplex was scratched so I ordered a replacement off of ebay. The rollbars have the holes already drilled, at least mine did, and it was pretty easy to install. You just need to buy a cheap rivet gun. There's loads of posts about the installation on this forum. All up it cost me about $300 Australian. It's well worth it.
Boxster Base, 2002 Manual, Black.
LN Single Row Pro IMS retrofit.
Pominoz is offline   Reply With Quote
