Old 02-18-2015, 06:42 PM   #21
Jager
Jager's Avatar
Originally Posted by luci5r View Post
That's a great idea! I will certainly do that.
I have a question about battery charging.
I have read the manual; read instructions across the Internet; seen YouTube videos, basically done my research. Just want to confirm if the following sounds about right before I begin charging the battery tomorrow using my battery charger:
A. Remove the terminals from the battery posts.
B. Take the positive clamp from the battery charger & attach it to the positive post on the battery.
C. Take the negative clamp from the battery charger & attach it to an unpainted metal on the chassis (example: the hood latch on the car body).
D. Plug the charger in the wall. Set the options. Good to go!
Sounds about right?
Thanks guys!
If you remove both terminals from the battery posts you will need to connect both clamps of the battery charger to the battery.
If you remove just the positive terminal you can connect the battery charger the way you described.
Jäger
300K Mile Club
