Old 02-18-2015, 06:32 PM   #20
luci5r
luci5r's Avatar
So you don't have to repeat this process, you might want to click the latch on the hood into the closed position with the hood up or open. That way your hood won't latch closed accidentally.
Just don't forget to unlatch it before you do close it for good.
That's a great idea! I will certainly do that.
I have a question about battery charging.
I have read the manual; read instructions across the Internet; seen YouTube videos, basically done my research. Just want to confirm if the following sounds about right before I begin charging the battery tomorrow using my battery charger:
A. Remove the terminals from the battery posts.
B. Take the positive clamp from the battery charger & attach it to the positive post on the battery.
C. Take the negative clamp from the battery charger & attach it to an unpainted metal on the chassis (example: the hood latch on the car body).
D. Plug the charger in the wall. Set the options. Good to go!
Sounds about right?
Thanks guys!
luci5r is offline   Reply With Quote
