Old 02-17-2015, 05:30 PM   #2
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by ppbon View Post
... pull the clutch pedal back with your hand.
That's normal after a clutch bleed.
Happy Boxstering,
Pedro
Originally Posted by gonzojive View Post
Thanks. For clarity, I did pull the pedal back up by hand, but when I press it down again it snaps back down all the way to the floor. Still normal?
I didn't bleed the brake lines yet.
Keep Pumping it. Pedal should firm up and stay up. As you bleed and make sure of two things the piston did not fall out of the clutch slave and there is constantly fluid in the master
