Old 02-16-2015, 07:32 PM   #1
Cebu
+1 on this method. I tried the method the OP used and it didn't work for me. I had an old cellphone cigarette lighter charger and cut the end off. I then connected to a battery charger and let it sit for a few minutes. I was then able to pop the trunk.
Originally Posted by keysguy View Post
try getting 12 volts through the cigarette lighter. Some of the battery jump boxes have a adapter that plugs into the lighter plug. (do not try and jump start the car through the cig lighter) All you need is enough juice to power up the the alarm to turn it off. Once the alarm is off you can pop open the hood. Hope that helps.
Cebu is offline   Reply With Quote
