Old 02-16-2015, 01:36 PM   #1
thom4782
thom4782's Avatar
You may have to use the emergency release cable to get it open.
It is located in the front passenger wheel well. If you can remove the front couple of pins (about 2 o'clock position), you should be able to peal back the liner to get to it. It's a steel look located aft to the headlight tray.
BTW: if you ever remove the front bumper cover, it's a great time to relocated the cable so you can access it through the tow hook hole.
