Old 02-16-2015, 08:03 AM   #15
PorscheFan5
Thanks guys. Few more questions:
1. I finally have some time to work on the car today afternoon. I found 2 tensioners - one horizontal on drivers side to the rear of the engine jutting out (1 ring), 2nd on passenger side jutting down (2 rings) - where is the third one (3 rings)?
2. When I turn the crank and get cylinder 1 to the top and crank marks matching for TDC, the locking pin in the tear drop hole in the crank is not going in. Am I missing something? I tried all the three holes, no luck. Before you ask how I know cylinder/piston 1 is at the top; I have taken out all the spark plugs and put in an endoscope in cylinder 1 where I can see the piston coming all the way up and the TDC marks on crank matches with the mark on case. I should be at TDC, correct?
Just want to make sure before I lock the crank on the rear with a plate, lock cams and try to pull the IMS flange.
PorscheFan5 is offline   Reply With Quote
