Old 02-13-2015, 06:05 PM   #23
Auf los!
Auf los!'s Avatar
Thank you, thank you.
Laflamme, the shift knob may be technically "aftermarket," but it is a factory knob, very similar to the 996 standard knob, but with a tiny Porsche crest. Back in 2001, when my car was built, you could specify that this very knob should be installed. Pretty as it is, though, it is much shorter than the original knob, and therefore has to be moved that much less, resulting in quicker shifting.
I have always felt that the shifter in the 986 was and is the poorest-engineered part of the car. I spent more than ten years shifting a 1999 Miata, you see, and that experience spoiled me forever, shifting-wise.
To me the original shift knob seemed way too long, making the shifts that much longer. So first I tried this Porsche Exclusive-department knob, and it was better, but not good enough. So I then tried the 997 shifter, and that wasn't good enough. Lastly I installed a B&M shifter, and in conjunction with the shorter shifter, it's giving me shorter shifts, but is still nowhere near as good as a Miata shifter.
The Miata shifter shaft descends directly into the transmission, whereas the Boxster shifter is connected to two 10-ft cables, so maybe a Boxster shifter is NEVER going to be as direct-feeling and short as a Miata. But a Porsche deserves to have an excellent shifter, so I've been eyeing the Numeric Racing shifter, but, jeez, it is expensive.
2001 Boxster S 6-speed, 2013 Boxster S PDK
Auf los! is offline   Reply With Quote
