Old 02-13-2015, 05:03 PM   #1
jsceash
jsceash's Avatar
You don't need the pan off to remove the axle. Take the bolt out of the trailing arm at the control arm. Mark and remove the adjustable bolt out of the control arm. Pop the toe arm joint. Swing the strut out the axle will all but fall on the ground.
