Old 02-10-2015, 05:27 PM   #1
mgfranz
Originally Posted by woodsman View Post
You can adjust the upper limit from the bottom of the door- outer 2 plugs I think. Maybe you can lower it .25" and other alignment will be adequate all around. Possibly 7mm torx or allen- I saw it in the Bentley manual.
I don't think it's an upper limit issue, I thought of that. With the doors open, windows on both sides full closed, the passenger side is about 3/16" laterally aft when looking at the "wing trim", the rubber gasket near the speaker pod. So if I lowered the upper limit, that gap would be even larger...
I found something in my Group 5 manual that mentions a lateral adjustment, but the text in #1 makes no sense to me. Is this to adjust the actual angle of the window in relation to the frame or the fore/aft?
mgfranz is offline   Reply With Quote
