Old 02-10-2015, 02:54 PM   #11
Reebuck1
Reebuck1
Gauge cluster
Thanks Trey T, I read your suggestion and I think I 've got it.
The solution looks like...change my the cluster coding values for a 996 cluster put into a 986, the order code (EEPROM ?)contained in the vehicle section of the DME needs to be set properly. In my case it would need to be set to the order code for a 996 cab so that the 996 cluster would be recognized and allow recoding. The order code would need to be set to either 996310 - Cabriolet USA or 996311 - Cabriolet RoW
Once this (EEPROM flash chip) is changed in the DME section, an entire scan of all the control modules needs to be carried out and then you will be allowed to enter into the instrument cluster module and change the coding to turn on cruise activate the temp & oil pres. displays. If the model type is still set to 986 or is blank in the vehicle data section, when the scanning of all modules is carried out the cluster won't be recognized as it will be looking for a 986 cluster.
Does that sound correct??
Reebuck1 is offline   Reply With Quote
