Old 04-17-2006, 02:54 PM   #1
98Boxster98
Originally Posted by deliriousga
Thanks Jim. I'll check the schematics and test the lines for voltage to see what happens. I'll order the part so it gets here and just keep it for future use if it's something else. You can never have too many backup parts, eh?
deliriousga - did you ever find out the problem? I assume that your convertible top wasn't functioning correctly also? My top is acting erratically. Sometimes it works, sometimes it doesn't. Frustrating at times. I ran an errand with the top down and couldn't put it back up. It may work later when I try. Today, the windows isn't dropping also. I will check later today using the alarm approach.
98Boxster98 is offline   Reply With Quote
