Old 02-06-2015, 01:14 PM   #1
steved0x
steved0x's Avatar
Originally Posted by ammonman View Post
Start by pulling the roll bar pads off beginning at one end. ... Snap the roll bar pads back into place using the existing fasteners and you are done.
+1 I take the roll bar pads on and off when I put my B-K roll bar extension bar on for track days. Very easy to do. I bought some of the extra little clips that the roll bar pad studs go into, part #9 on this diagram:
Wind Deflector And Linings Roll-over Bar
I didn't really need to use them but I used one or two anyway since I had them.
When you pull off the roll bar pad, these fasteners will either stay in the rollbar, or come off on the stud. If it comes off on the stud, you can just thread it off.
When it is time to put the roll bar pad back into the car, put the clips in the holes, then line up the roll bar pad studs over the hole, gently get them started, and then pop the pad with the heel of you hand to pop it in.
