While you are doing spark plugs, you may want to replace the spark plug tubes if you have any oil leaking from them. Also, get some clutch spline grease for the transmission input shaft and inspect your CV joint boots. If you have torn boots, you may want to order new boots and associated parts while the tranny is out.
