Old 02-05-2015, 12:41 PM   #1
Meir
1999 base
Meir's Avatar
Thanks, I already have the secondary bypass cat pipes.....will I just need to remove these or the complete exhaust system ?
Also if my splines come out easy will I still need to replace the rear axle nuts ??
Dwight
just the bypass pipes.
and yes. the nuts needs to be replaced anyway.
also take in mind you will need to torque them to 340 ft-lbs, so you need a very large torque wrench, or use the method described in this writ up fig 15:
Pelican Technical Article: Boxster Wheel Bearing Replacement - 986 / 987
i also assume you have the SIR tool Pelican Parts - Product Information: PEL-TOL-SIRB90-P2 ore you will not be able to remove the bearing with the hub on the car.
