Old 04-16-2006, 07:49 PM   #5
Cold Warrior
Originally Posted by deliriousga
Too much stress on the drive. It will work fine and feel fine, but the dampening springs that are built in the original dual-mass flywheel keep the drive and gears from being over-torqued and stressed. If you put a lighweight flywheel in, you need a matching clutch disc that has the dampening springs built in it or eventually you could snap the drive shaft and/or tear up a gear or two.
Isn't this a problem only if you dump the clutch?
CW
"Lotta people go through life doing things badly.
Racing's important to men who do it well.
When you're racing, it's life.
Anything that happens before or after is just waiting."
-M. Delaney (Steve McQueen, "Le Mans")
Cold Warrior is offline   Reply With Quote
