Old 04-16-2006, 07:24 PM   #4
deliriousga
deliriousga's Avatar
Originally Posted by Cold Warrior
Not quite sure what you are talking about. My 2000S has a LWF with the stock clutch disc and it works perfectly.
CW
Too much stress on the drive. It will work fine and feel fine, but the dampening springs that are built in the original dual-mass flywheel keep the drive and gears from being over-torqued and stressed. If you put a lighweight flywheel in, you need a matching clutch disc that has the dampening springs built in it or eventually you could snap the drive shaft and/or tear up a gear or two.
1966 Wife White/Brown Top
