Old 04-16-2006, 09:47 AM   #12
MNBoxster
Hi,
The new DOT Mandated inflation figures are for a fully loaded vehicle - the Legacy of the Firestone/Ford Explorer Rollovers. As such, these are most likely not good for you if you don't have the Fuel Tank Full, both Trunks Full and ride with a Passeneger - ALL THE TIME!
With the low profile Tires, don't go below 34PSI or you could damage a Rim and don't go higher than say 39PSI. The Fronts should be equal to or lower than the Rears. Anywhere in-between these guidlines will be fine. I use 35PSI Front and 37PSI Rear - Hope this helps...
Happy Motoring!... Jim'99
