Old 01-25-2015, 05:59 PM   #1
kk2002s
kk2002s's Avatar
Mine is Front Lower control arm ball joint
I spray WD-40 yes WD-40 into the boot and everything is quite for 1000s of miles
My boots are cracked so there is probably dirt and all in there so I will be replacing Lower control arms (If TRW ever decides to make any more) and tie rods before spring
Check your ball joint boots. You to may see that they are deteriorated and so contaminated with road grim contributing to the noise
Seal Grey
