Old 01-15-2015, 12:55 PM   #1
thstone
Its good reading, I have to admit.
In terms of "what does this mean to me?", the remaining question in my mind is how the oil pressure test results (in psi) relate to the actual pressures between components in a real engine?
For example; if the "pressure" in a bearing is only 50,000 psi then every oil tested will adequately meet the pressure required to avoid serious wear.
On the other hand, if engine friction surface "pressures" vary from 50K psi to 100K psi, then the data implies that using a different oil may preclude wear.
The author never tells us what the MINIMUM pressure is to preclude wear. Is higher better? Probably. But what pressure level is "good enough" versus "not good enough"?
