Old 01-14-2015, 08:37 PM   #19
Chuck W.
Chuck W.'s Avatar
Originally Posted by jim_hoyland View Post
Interesting; how does it work ? Does it come on upon start up, do you reset it between drives ? Curious as to how much attention a unit like this requires....
I have it hardwired so that it turns on and off with the car. It records to the 32 gb micro sd card. It is on a loop and will record over itself. Depending on the size of the sd card and the setting you have set up for the camera, you can get from eight to thirty hours before it records over itself.
I pull it out every couple of weeks to ensure it is working and format the sd card just as a maintenance measure.
That is a sweet looking ride you have there Chuck, striking interior!
White face gauges and Red seat belts are my two fav from your list Chuck, from your mod list what is a Bird Arm Rest? this turned out when I googled? you got a new tattoo?
Thanks. No tattoos... just a custom armrest that gives you more storage space.
1995 Porsche C4 Cab
