Old 01-14-2015, 03:13 PM   #17
crooster
101 projects has this as very simple job requiring only a floor jack.
Under $200 for a new 987 mount and 2 hours of DIY time.
I did mine last summer. Two hours sounds about right. Not a hard job but it is tight to get at the bolts. I suggest using a mechanical jack under the engine so you can make small adjustments to get everything aligned. Also a set of ratcheting wrenches came in handy.
Chris
'86 944, manual steering, a/c delete, 944Max chip
'87 951, K27, LBE, Turbo S brakes, Koni Yellows, Weltmeister sway bars / strut brace, LSD, full cage, OMP race seats
'01 Boxster - Seal Grey / Black / Black, Litronics upgrade / de-ambered
crooster is offline   Reply With Quote
