Old 01-10-2015, 03:35 PM   #1
Redboxs
Pulling the motor! Need advise
Ok, so since it is winter and I am not going to get much use from my car for the next 8 weeks or so.. I am going to pull the motor to do some maintenance!
What I plan on doing..
Water pump OEM
low temp thermostat
power steering pump ( I had a leak and left it whining)
AOS
IMS
alternator
belt
plugs, coil packs, tubes with new gaskets
Acc pulleys
clean throttle body
Exhaust
front motor mount
What else should I do while it is out of the car? The clutch and flywheel were done less than 100 miles ago. Vanos was done less than 1000 miles ago. What else should I plan on doing? I just want it to be reliable and dependable. Thanks for the input!
Redboxs is offline   Reply With Quote
