					Originally Posted by  pjq
				I didn't use the special tool, I just removed my engine took it apart and sent the IMS to LN and they pinned and installed a triple row bearing. No special tool required!! haaaaaa!
How much did LN charge you to pin your shaft and install that three row bearing?
To the OP, on Wayne's site he shows use of a gear puller to remove the bearing. The tools sure do make it an easy job.
