Originally Posted by denverpete
Jim - If I'm not mistaken, they will fix this for free only under warranty - correct? I was reading somewhere that it's not necessarily a cheap fix (but what is?).
Hi,
I have no idea if it's a Warranty item or not, probably is though. In the TSB it states:
- Labor Operation # : 20 15 19 99 * Time: 70 TU Description: Remove and install fuel level sensor. Perform fuel hose modification
* State: "Fuel Tank Hose Modification" in claim drop-down box.
This leads me to believe that you are correct, but it's worth checking. Also, if it's that bad to refill, there may be little choice but to have the work performed. If you have the procedure and don't mind working around the open Fuel Tank, it appears to be a fairly easy DIY task...
Happy Motoring!... Jim'99
