Old 12-30-2014, 07:06 PM   #2
Cebu
This sounds like my HD Roadglide for my bike I use a trickle charger. What is your opinion with the Boxster? Use a trickle charger via the cigarette lighter receptacle? Thank you for the response and tip on the latch removal.
Originally Posted by Joe B View Post
Common problem. These cars have a lot of drain on the batteries. If I leave mine for more than a week or so, I disconnect the negative wire from the battery, or I hook up my C-tek charger. Just don't latch the frunk with the battery disconnected (I remove the catch; 2-10 mm head bolts).
Cebu is offline   Reply With Quote
