Old 04-11-2006, 08:06 PM   #1
Biz-z Z
Originally Posted by BadBoyS
Biz,
Just did this recently no real trick. Unscrew the filter housing (need to use a filter wrench) pull the filter off stick the new one on (put the new o ring on the housing tighten to spec DONE..
BB
Thanks for your reply. I was thinking more along the lines of what do you “stick the new one on” to? What holds the filter element in place so you can then reinstall the “filter housing”?
Also, what specs for the plug and the filter housing? Somewhere I read 35 lbs/ft and 18 lbs/ft respectively? Are these what you have used and or does Porsche have other numbers?
Thanks.
Zib
Biz-z Z is offline   Reply With Quote
