Old 12-16-2014, 08:12 PM   #3
Gelbster
I too am investigating this subject but am hesitating for lack of much discussion of this subject -so thanks BY.
Please correct me but I understand the upgrade injector is a Bosh Gen 3 ,part # 0280155890. The Porsche # is 996 606 120 00 ? This is a '4 hole' injector.
My originals work fine but as part of my engine rebuild I need either a repair kit or the upgraded injectors. The repair/service kit is $25 for all 6.If I send my originals out for service +flow test it is $300+. The 6 new,upgraded Bosch injectors are $315.
Check your injectors before you buy -if they are a dirty beige color and have "0280 156 053" on the side, they are 4 hole, Gen 3.The problem is you have to remove one injector to read this number.
"This Bosch injector replaces obsolete p/n 0290150455.
Bosch Part number: 0280155890
Flow specs: 22.7 LBS/HR at 3 BAR (172.4 g/min)
Fuel Nozzle: Modern 4-hole disc fuel atomizer
Spray Type: Narrow cone, maximum fuel atomization
Injector type: Saturated
Connector type: Jetronic
O-rings: Viton, 14.5 mm
Length: 74 mm
Coil resistance: 12.0 Ohms"
