Old 04-10-2006, 06:57 PM   #1
deliriousga
deliriousga's Avatar
If the A/C compressor is on, the fan will be on. If it seems to be on all the time, the relay or temp sensor for the fan may have failed. The temp sensor a little stick that is held between the intake "spider" pipes on the passenger side of the engine compartment.
If there's a real problem with the engine compartment fan, the light on the temp guage should flash to warn you.
1966 Wife White/Brown Top
