Thread: Metal in filter
Old 12-07-2014, 07:04 PM   #5
rp17
rp17's Avatar
First off, the source of the debris must be found. If it isn't, and you just assume its the IMSB, and retrofit it, the chances of the replacement bearing failing are insanely high. Why? Because you have debris suspended in the life blood (oil) of the engine and the smaller and lighter it is, the easier it travels everywhere throughout the .
Listen to this advice. Open bearing is susceptible to this.....
