Old 12-03-2014, 01:03 PM   #4
Qmulus
inveniam viam aut faciam
Originally Posted by jim_hoyland View Post
Do you have the replacement side pieces to accommodate the switch ?
I assume that you mean the rubber "gasket" that is in the steering column trim? All you need to do is cut a hole in the one that is there. There are marks molded into the back side of the rubber gasket that shows where to cut. It takes about a minute with a hobby knife or sharp box cutter. You could probably cut it with a sharp scissors as well.
I do have that gasket that was from a car that had the OBC from the factory, and it almost looks like they just tore the center of the gasket out. That one is going with a complete '01+ S manual dot matrix OBC cluster, four stalk switch and harness that I will be listing soon.
Qmulus is offline   Reply With Quote
